62495 Prodotti per ogni genere di creazione!
Kheops and MiniDuo bracelet di Puca
Abbrevations :
Kheops par Puca = K
MiniDuo = MD
Round bead 4 mm = R
Rocaille seed bead 8/0 = M8
Rocailles seed bead 11/0 = R11
Rocailles seed bead 15/0 = R15
Step 1 :
Slip on teh thread 1 Kheops and 2 Mini duo.
1_39
Step 2 :
Repeat 3 times the step 1. you should have this :
3_39
Step 3 :
put 1 R15, 1 R, 1 R15 between the Khéops.
4_26
Step 4 :
Insert 1 R15 between each  MD and go around.
5_18
Step 5 :
Slip 2 R15.
6_16
Step 6 :
put 2 R15.
7_10
Step 7 :
put 2 R15.
8_08
Step 8 :
slip 1 R11 and repeat the steps 6 and 7.
9_06
Step 9 :
Placeyou inside the R15 with the star. You should obtain this  :
10_07
Step 10 :
Slip 6 R15.
11_08
Step 11 :
Slip then  1 R15, 1 R11, 1 R15 and go out at the star.
12_07
Step 12 :
put 1 R15, 1 R11, 1 M8, 1 R11 and 1 R15.
13_05
step 13 :
slip1 R15, 1 R11, 1 R15 and close your thread.
14_06
Step 14 :
Repeat the steps 1 - 10 to reproduce the same element we have just achieved.
16_02
Step 15 :
Now we will assembly both elements.
17_03
Step 16 :
Slip 1 R15.
18_02
Step 17 :
Put 2 R15 and go at the star out.
19_03
Step 18 :
Slip 1 R15, 1 R11, 1 M8, 1 R11, 1 R15.
20_01
Step 19 :
Insert  2 R15 in the R11.
22_01
Step 20 :
put 1 R15.
23_01
Step 21 :
Insert  2 R15 in the central 2 R15.
25_01
Step 22 :
To finish slip 2 R15, tight well and close.
26
Step 23 :
Ass a jumpriong at both sides
28
tifany_collection_argent_nom
Copyright Création Puca per Perlesandco.com 2015. Tutti i diritti riservati. Riproduzione, anche parziale, vietata sin l'accordo dell'autore. http://perlepuca.canalblog.com/
