61280 Prodotti per ogni genere di creazione!
Tutorials / Fête des grand mères / Bracciale in estate indiana con perle © Arcos e Minosse © Shapers Swarovski
A big thank you to Olga  for this tutorial.
bracelet-ete-indien-arcos-toupies-swarovski-materiel
STEP 1
String two Arcos, opposite each other , then one bicone, repeat four times. Tight a knot to from a circle and weave again through all beads.
bracelet-ete-indien-arcos-toupies-swarovski-01
Step up to the second hole of Arcos bead.
bracelet-ete-indien-arcos-toupies-swarovski-02
STEP 2
Put one Minos between Arcos, then string one 15, Crescent, one 11 seed bead, one Crescent, 15 seed bead.  Repeat tree more times.
bracelet-ete-indien-arcos-toupies-swarovski-03
bracelet-ete-indien-arcos-toupies-swarovski-04
Step up to the second hole of Crescent bead
STEP 3
Reverse the beading and work on the backside.  String one 11 seed bead between Crescents, then two 11, bicone 4mm, two 11. Pass throught next Crescent. Repeat tree more times.
bracelet-ete-indien-arcos-toupies-swarovski-05
 Put 18mm rivoli in center. Weave again through this circle and step up to the bicone.
bracelet-ete-indien-arcos-toupies-swarovski-06
STEP 5
String two 15, bicone, two 15, pass to next bicone. Repeat three more times. Step up to the bicone.
bracelet-ete-indien-arcos-toupies-swarovski-07
STEP 6
String one 11 and pass to the bicone, Repeat three more times and weave again through all beads to secure the rivoli
bracelet-ete-indien-arcos-toupies-swarovski-08
STEP 7
Weave through beads to exit from Arcos third hole.
bracelet-ete-indien-arcos-toupies-swarovski-09
String one 15, two 11, bicone 6mm, two 11, one 15. Repeat tree times. Weave again through all beads and exit bicone 6mm.
bracelet-ete-indien-arcos-toupies-swarovski-10
STEP 8
Exit from 6mm bicone, string one 11 seed bead, one Arcos,15,bicone,15,bicone,15 seed bead and pass through the third hole of Arcos.
bracelet-ete-indien-arcos-toupies-swarovski-11
Then string one 11 and pass through bicone 6mm. weave to exit second 15 seed bead added.
bracelet-ete-indien-arcos-toupies-swarovski-12
STEP 9
String one bicone, one 15, one Arcos.
bracelet-ete-indien-arcos-toupies-swarovski-13
STEP 10
String one 15,bicone,one 15,bicone,one 15 and pass through two Arcos.
bracelet-ete-indien-arcos-toupies-swarovski-14
STEP 11
String one 15 seed bead, one bicone and pass through 15 seed bead between three bicones. Then weave to the second 15 seed bead added in step 10.
Repeat step 9-11 until you get desired length. End on step 9.
STEP 12
String 4 11 seed beads and  pass through the opposite hole of Arcos bead.
bracelet-ete-indien-arcos-toupies-swarovski-15
Then weave through11, bicone,15 and again through Arcos and 4 11 seed beads, adding 15 seed beads between 11.
STEP 13
Weave to exit side hole of Arcos bead. String three 15 seed beads, pass through the center hole of Arcos, string one Minos bead, pass through the center hole of the other Arcos bead.
bracelet-ete-indien-arcos-toupies-swarovski-16
String three 15 seed beads and pass through the side hole of Arcos.
String three 15 seed beads, pass through the center hole of Arcos, weave through the Minos and center of Arcos, string three 15 seed beads and pass through the other side hole of Arcos.
Repeat this Step with the other pair of Arcos.
bracelet-ete-indien-arcos-toupies-swarovski-17
STEP 14
Weave to 6mm bicone and exit from the side hole of the nearing Arcos bead.
String six 15 seed beads and pass through the other side of Arcos bead.
bracelet-ete-indien-arcos-toupies-swarovski-18
Secure and trim the thread.
STEP 15
Add a new thread.
Make the same chain on the opposite side of the centerpiece.
STEP 16
 Attach desired clasp to the ends with jump rings and enjoy your creation!
bracelet-ete-indien-arcos-toupies-swarovski-vf2
Copyright Olga Karaulova - 2016.
Trovate altri modelli facendo clic su : https://www.instagram.com/tinearen/
