62731 Prodotti per ogni genere di creazione!
Tutorials / Perline a spirale / spiral crochet bracelet with beads
Difficult
To make this bracelet you should know the base of the hook : chain stitch, stitch and crochet
Step 1 :
First thread all  Miyuki 11/0 Rocailles on a  C-LON Micro Cord with a  beading needle.
Tip: take some colours easy to follow.
Here we take a sequence with 3 beads: green, pink, silver ...
Thread 600 beads on a bracelet
You can also hinfügen what if some are missing.
We work with a spiral with 6 pearls.
Bracelet spirale au crochet en perles Miyuki
Step 2 :
We start with the first row:
Make a lock and begin with a first chain stitch.
Step 3 :
Repeat with the 5 following beads.
Step 4:
Close the circle of 6 beads.
Step 5:
Then do the second row. Crochet the thread right from the bead like this.
Step 6 :
Put the silver colour bead
Step 7:
Make a single crochet by snapping to the new bead (pull the hook through 2 locks)
The bead comes in its place.
Step 8:
The beads come to their place when you make the next row
Crochet so on
Tip: If you need to add thread then hide him through the previous series
tuto_bracelet_spirale_crochet_miyuki
Copyright Anne Bermond per Perles & Co - 2016.
Trovate altri modelli facendo clic su : https://www.instagram.com/monjolitricot/
