62723 Prodotti per ogni genere di creazione!
Tutorials / Customizzazione / Personalizzazione di un cappello con cristalli Swarovski
Step 1 :
Cut the Alcantara to the appropriate length of your hat and make one of the ends into an arrow shape. Create a transfer
as shown in the illustrations with this step using the Swarovski Hotfix Flat Backs and iron it onto the Alcantara.
customisation_chapeau_swarovski
Step 2 :
Sew one end of the Alcantara onto the hat and place the entire length around the hat.
Step 3 :
Insert the rest of the Swarovski Crystals on the material list onto the nylon stretch cord. Tie a double knot at end and cut off the extra length.
Step 4 :
Put some glue onto the knot and insert the knot into one of the Swarovski Crystals near to it. Let dry for a couple of minutes and lay it around the hat.
Copyright Swarovski create your style per Perles & Co - 2016.
Trovate altri modelli facendo clic su : http://www.create-your-style.com/
