2 Recensioni
Gancio per pendente da 8 mm - Argento 925 x1
Codice : SL-900
Pendente fiori mm. 50 legno decorato Pop x1Pendente fiori mm. 50 legno decorato Pop x1
> 4
0,98 €
Mini Pera PureCrystal 6128 12 mm Crystal  x1Mini Pera PureCrystal 6128 12 mm Crystal  x1
1,06 €
0,87 €
Mini Pera PureCrystal 6128 12 mm Denim Blue x1Mini Pera PureCrystal 6128 12 mm Denim Blue x1
Mini Pera PureCrystal 6128 12 mm Peridot x1Mini Pera PureCrystal 6128 12 mm Peridot x1
Strass Hotfix PureCrystal mm. 3 Peridot x36Cabochon PureCrystal 1088 mm. 8 PeridotCabochon PureCrystal 1088 mm. 3 Peridot x20Cabochon PureCrystal 1122 Rivoli mm. 12 PeridotCabochon PureCrystal 1122 Rivoli mm. 8 Peridot
+8
Cuore PureCrystal 6228 mm. 14,4x14 Crystal Heliotrope x1Cuore PureCrystal 6228 mm. 14,4x14 Crystal Heliotrope x1
Pendente De-Art PureCrystal 6670 mm. 18 Crystal Bermuda Blue x1Pendente De-Art PureCrystal 6670 mm. 18 Crystal Bermuda Blue x1
Lacrima PureCrystal 6106 mm. 16 Crystal Antique Pink x1Lacrima PureCrystal 6106 mm. 16 Crystal Antique Pink x1
Lacrima PureCrystal 6106 mm. 16 Aquamarine x1Lacrima PureCrystal 6106 16mm Aquamarine Shimmer x1Lacrima PureCrystal 6106 16mm Citrus Green x1Lacrima PureCrystal 6106 16mm Reinvented Cool Blue  x1Lacrima PureCrystal 6106 mm. 16 Crystal  x1
+13
PureCrystal Starfish 6721 16 mm - Cristallo AB x1PureCrystal Starfish 6721 16 mm - Cristallo AB x1
PureCrystal Starfish 6721 16 mm - Cristallo x1PureCrystal Starfish 6721 16 mm - Cristallo blu Bermuda x1PureCrystal Starfish 6721 16 mm - Indicolite x1
Pendente PureCrystal 6428 mm. 12 Crystal AB x1Pendente PureCrystal 6428 mm. 12 Crystal AB x1
Pendente De-Art PureCrystal 6670 mm. 18 Crystal AB x1Pendente De-Art PureCrystal 6670 mm. 18 Crystal AB x1
Lacrima PureCrystal 6106 mm. 16 Crystal  x1Lacrima PureCrystal 6106 mm. 16 Crystal  x1
Lacrima PureCrystal 6106 mm. 16 Aquamarine x1Lacrima PureCrystal 6106 16mm Aquamarine Shimmer x1Lacrima PureCrystal 6106 16mm Citrus Green x1Lacrima PureCrystal 6106 16mm Reinvented Cool Blue  x1Lacrima PureCrystal 6106 mm. 16 Crystal AB x1
+13
PureCrystal Starfish 6721 16 mm - Indicolite x1PureCrystal Starfish 6721 16 mm - Indicolite x1
PureCrystal Starfish 6721 16 mm - Cristallo x1PureCrystal Starfish 6721 16 mm - Cristallo AB x1PureCrystal Starfish 6721 16 mm - Cristallo blu Bermuda x1
PureCrystal Starfish 6721 16 mm - Cristallo x1PureCrystal Starfish 6721 16 mm - Cristallo x1
PureCrystal Starfish 6721 16 mm - Cristallo AB x1PureCrystal Starfish 6721 16 mm - Cristallo blu Bermuda x1PureCrystal Starfish 6721 16 mm - Indicolite x1
PureCrystal Starfish 6721 16 mm - Cristallo blu Bermuda x1PureCrystal Starfish 6721 16 mm - Cristallo blu Bermuda x1
PureCrystal Starfish 6721 16 mm - Cristallo x1PureCrystal Starfish 6721 16 mm - Cristallo AB x1PureCrystal Starfish 6721 16 mm - Indicolite x1
Lacrima PureCrystal 6106 mm. 16 Crystal Silver Night x1Lacrima PureCrystal 6106 mm. 16 Crystal Silver Night x1
+13
Cuore PureCrystal 6225 mm. 18 Crystal x1Cuore PureCrystal 6225 mm. 18 Crystal x1
Cabochon PureCrystal 4884 Cuore mm. 11x10 Crystal x1Cabochon PureCrystal 1088 mm. 8 CrystalCabochon PureCrystal 4610 mm. 18x13 CrystalCabochon PureCrystal 1122 Rivoli mm. 12 CrystalCabochon PureCrystal 4320 pera mm. 14x10 Crystal
+29
Lacrima PureCrystal 6106 mm. 16 Jet x1Lacrima PureCrystal 6106 mm. 16 Jet x1
+13
Lacrima PureCrystal 6106 mm. 16 Crystal Golden Shadow x1Lacrima PureCrystal 6106 mm. 16 Crystal Golden Shadow x1
+13
Lacrima PureCrystal 6106 mm. 16 Crystal AB x1Lacrima PureCrystal 6106 mm. 16 Crystal AB x1
+13
Da anonyme (10/02/2020 19:44:43)
Compatible avec GOUTTE BAROQUE PureCrystal 6090 16X11 MM ou il vaut mieux une attache de 10 mm? Merci
Il nostro esperto ti risponde (11/02/2020 09:36:42)
Oui c'est compatible mais c'est aussi compatible avec une attache de 10mm
La tua recensione (2)
Da Véronique (pubblicato su : 24/04/2023 )
Bonjour, sincèrement, Il est impossible de commander en toute confiance vos bélières car les dimensions sont mal renseignées. Pourriez-vous donner les dimensions du passe-cordon, les dimensions de l'anneau de l'attache et les dimensions de l'attache, ainsi que la hauteur entre les tiges et le haut de l'attache. Le trou des pendentifs n'est jamais à la même hauteur, d'où l'importance des dimensions de vos attaches. Merci infiniment.
Il nostro esperto ti risponde (25/04/2023 09:53:33)
Bonjour, toutes les informations que vous avez besoin sont déjà renseignées dans notre fiche produit :
Longueur de l'attache : 8 mm
Largeur de l'attache : 2.75 mm
Longueur totale (avec anneau) : 12 mm
Diamètre des tiges : 0,9 mm
Longueur des tiges : 1,9 mm
Dimensions de l'anneau de l'attache : 4 x 3 mm
Diamètre du trou de l'anneau de l'attache : 4 mm
Da alexandra (pubblicato su : 16/12/2021 , acquistato su : 13/12/2021)
si par le passé il y a eu des soucis, a ce jour les attaches pendentifs sont très bien, merci :-)
