Base in ottone per bracciale Eco con bordo incurvato mm. 24.5 dorato x1
Codice : BRACELET-303
Manchettes
Bracciale
Le tue domande (3)
Da Ulrika (05/10/2026 11:34:15)
Could you pls explain Gold Tone. Is that like fine gold plating or? Thanks for explaning for this particualr bracelet.
Il nostro esperto Maeva ti risponde (06/10/2026 08:41:20)
Hello, "Gold Tone" (Doré) refers to the electroplated finish applied to the brass base. It is a galvanic plating, not solid gold or fine gold plating. Thank you
Il nostro esperto Manon ti risponde (07/10/2026 16:46:09)
Hello, "Gold Tone" (Doré) refers to the galvanic finish of the bracelet: the brass base is electroplated with a thin layer giving it a gold color. It is not fine gold plating (no karat gold involved). The item is however lead-free, cadmium-free and nickel-free, as indicated on the product sheet.
Il cliente Ulrika K. risponde (06/10/2026 09:30:33)
Thank you for clarifying. Could you please confirm what metal the Gold Tone (Doré) plating actually consists of? Does the plating contain real gold, and if so, what gold purity (e.g. 18K or 24K) and approximately how many microns thick is the plating?
Da Clementine (03/10/2024 19:03:25)
Bonjour cette aille suffit elle pour un bracelet de 15 perles miyuki 11/0 en tissage peyote svp?
Il nostro esperto Tiffanie J. ti risponde (04/10/2024 10:14:20)
Bonjour, ça devrait passer mais ça va être juste juste.
Da stéphanie (21/04/2021 10:42:53)
Bonjour, quand cet article sera à nouveau disponible ?
Il nostro esperto ti risponde (21/04/2021 15:36:45)
Bonjour, ce bracelet sera disponible d'ici lundi.
