Castone per cabochon rotondo da 4 mm - Gold filled x1
Codice : GFD-040
10 > 99
Cabochon rotondi 4mm Turchese imitazione x5Cabochon rotondi 4mm Turchese imitazione x5
Cabochon rotondi 4mm Ametista x5Cabochon rotondi 4mm Ametista x5
Cabochon rotondi 4mm Amazonite x5Cabochon rotondi 4mm Amazonite x5
Da Betül (02/08/2024 21:18:56)
Hey, I want to make a ring with this. Can you recommend me what stone type and size i can use? Also is it possible to put the stone inside and then close the bezel with a tool HRA-577 ? Or is it only possible with glue..
Thank you for your help!
Il nostro esperto Julie D. ti risponde (03/08/2024 15:20:10)
Hello,
This setting is made for cabochon 4 mm to be glued. Thank you for your question.
Da K Le (09/05/2024 18:26:18)
what is the height of this bezel cup?
Il nostro esperto Manon L. ti risponde (10/05/2024 10:24:02)
Hello,
Diameter: 4.8 mm
Internal diameter: 4 mm
Thickness: 1.4 mm
