Tappetino per le perle misura grande 80x60 cm beige x1
Codice : OTL-665
Microsfere
Microsfere
Aghi
Aghi
Miyuki Delica 11/0
Miyuki Delica 11/0
Rocailles
Rocailles
Braccialetto polsino con perline rocailles
Le tue domande (3)
Da Shira (08/11/2025 09:59:51)
Merci beaucoup pour les superbes photos.
Da Shira (17/10/2025 02:51:32)
Hello,
Could you please state how thick this mat is and how thick are OUTIL-037 and OUT-392? Or maybe add a photo from the side - it is hard to understand this product's characteristics from the current folded picture and to compare it to close products before buying. Thank you.
Il nostro esperto Maeva ti risponde (22/10/2025 09:49:00)
Hello, we’ve updated the photo to make it clearer. The thickness of this mat is 4 mm, while OUTIL-037 is 5 mm thick (as stated on its product page). The OUT-392 mat has a thickness of 4 mm.
We’ll also be adding these details directly to each product sheet for easier comparison.
Da Jacki Dunning (07/07/2024 12:20:38)
Is this mat vellux material please
Il nostro esperto Manon L. ti risponde (09/07/2024 08:26:57)
Hello, the bead mat is polyurethane foam core + surface nylon fiber.
