Strass da incollare PureCrystal mm. 4
Filtrare39 articolo(i)
Strass da incollare PureCrystal mm. 4 Crystal Heliotrope x36Strass da incollare PureCrystal mm. 4 Crystal Heliotrope x36
Cuori PureCrystal 6228 Crystal Heliotrope mm. 10,3x10 x6Cuore PureCrystal 6228 mm. 18x17.5 Crystal Heliotrope x1Cuore PureCrystal 6228 mm. 14,4x14 Crystal Heliotrope x1Strass da incollare PureCrystal mm. 6 Crystal Crystal Heliotrope x10Strass da incollare in cristallo PureCrystal 2200 8x4 mm - Crystal Eliotropio x8
Strass da incollare PureCrystal mm. 4 Crystal Bermuda Blue x36Strass da incollare PureCrystal mm. 4 Crystal Bermuda Blue x36
Pendente Spike PureCrystal 6480 28 mm Crystal Bermuda BluePureCrystal Ciondolo taglio marquise 6437 9x4,5 mm - Cristallo blu bermuda x1Pendente PureCrystal 6438 Elliptic Cut Pendant 16 mm - Crystal Bermuda Blue x1Pendente PureCrystal 6438 Elliptic Cut Pendant 11.5 mm - Crystal Bermuda Blue x1Pendente PureCrystal 6438 Elliptic Cut Pendant 9 mm - Crystal Bermuda Blue
+19
Strass da incollare PureCrystal mm. 4 Crystal Vitrail Medium x36Strass da incollare PureCrystal mm. 4 Crystal Vitrail Medium x36
Cabochon PureCrystal 4499 6 mm Crystal Vitrail Medium x1Cabochon PureCrystal 4841 mm. 4 Crystal Vitrail Medium x1Cabochon PureCrystal 4745 Stella mm. 10 Crystal Vitrail Medium x1PureCrystal Ciondolo taglio marquise 6437 9x4,5 mm - Cristallo Vitrail Medio x1PureCrystal 6430 Ciondolo da 8 mm - Cristallo Vitrail medio x1
+21
Strass da incollare PureCrystal mm. 4  Reinvented Dark Jonquil x36Strass da incollare PureCrystal mm. 4  Reinvented Dark Jonquil x36
Cabochon PureCrystal 4120 ovale 14x10 mm - Reinvented Dark Jonquil x1Cabochon Fleur PureCrystal 4744 10 mm - Reinvented Dark Jonquil x1Cabochon PureCrystal 4320 6x4 mm - Reinvented Dark Jonquil x1Cabochon PureCrystal 4470 12 mm - Reinvented Dark Jonquil x1Cabochon PureCrystal 1122 Rivoli mm. 14 Reinvented Dark Jonquil x1
+25
Strass da incollare PureCrystal mm. 4 Crystal Orchid Ignite x36Strass da incollare PureCrystal mm. 4 Crystal Orchid Ignite x36
Cabochon PureCrystal 4627 mm. 27x18,5 Crystal Orchid Ignite x1Cabochon PureCrystal 1088 6mm Crystal Orchid Ignite x1Cabochon PureCrystal 1088 8mm Crystal Orchid Ignite x1Cabochon PureCrystal 1122 Rivoli 12 mm - Crystal Orchid Ignite x1Cabochon PureCrystal 1122 Rivoli mm. 14 Crystal Orchid Ignite x1
+10
Strass da incollare PureCrystal mm. 4 Crystal Mango Ignite x36Strass da incollare PureCrystal mm. 4 Crystal Mango Ignite x36
Cabochon PureCrystal 4627 mm. 27x18,5 Crystal Mango Ignite x1Navetta PureCrystal 4228 10x5 mm - Cristallo Mango Ignite x1Cabochon PureCrystal 1088 6mm Crystal Mango Ignite x1Cabochon PureCrystal 1088 8mm Crystal Mango Ignite x1Cabochon PureCrystal 1122 Rivoli 12 mm - Crystal Mango Ignite x1
+10
Strass da incollare PureCrystal mm. 4 Crystal Pine Green Ignite x36Strass da incollare PureCrystal mm. 4 Crystal Pine Green Ignite x36
Strass da incollare PureCrystal mm. 4 Crystal Vitrail Light x36Strass da incollare PureCrystal mm. 4 Crystal Vitrail Light x36
Strass da incollare PureCrystal mm. 4 Crystal Soft Rose Ignite x36Strass da incollare PureCrystal mm. 4 Crystal Soft Rose Ignite x36
Strass da incollare PureCrystal mm. 4 Reinvented Cool Blue  x36Strass da incollare PureCrystal mm. 4 Reinvented Cool Blue  x36
Strass da incollare PureCrystal mm. 4 Dark Rose x36Strass da incollare PureCrystal mm. 4 Dark Rose x36
Navette PureCrystal 4228 6x3 mm - Dark Rose x4Cabochon PureCrystal 4320 14x10mm - Dark Rose x1Cabochon PureCrystal 4320 18x13 mm - Dark Rose x1Cabochon PureCrystal  4470 10mm Dark Rose x1Cabochon PureCrystal  4470 12 mm - Dark Rose x1
+25
Strass da incollare PureCrystal mm. 4 Crystal Soft Mint Ignite x36Strass da incollare PureCrystal mm. 4 Crystal Soft Mint Ignite x36
Strass da incollare PureCrystal mm. 4 Crystal Soft Yellow Ignite x3Strass da incollare PureCrystal mm. 4 Crystal Soft Yellow Ignite x3
Cabochon PureCrystal 4320 14x10mm - Crystal Soft Yellow Ignite x1Cabochon PureCrystal 4320 18x13 mm - Crystal Soft Yellow Ignite x1Cabochon PureCrystal  4470 10mm Crystal Soft Yellow Ignite x1Cabochon PureCrystal  4470 12 mm - Crystal Soft Yellow Ignite x1Cabochon PureCrystal 1088 6mm Crystal Soft Yellow Ignite x1
+6
Strass da incollare PureCrystal 4 mm Light Siam x36
Navetta PureCrystal mm. 15x7 Light SiamNavetta PureCrystal mm. 10x5 Light SiamCuori PureCrystal 6228 Light Siam mm. 10,3x10 x6Pendente PureCrystal 6428 mm.  6 Light Siam x1Perla tonda Thin Round  PureCrystal 5034 8 mm - Light Siam x1
+23
Strass da incollare PureCrystal mm. 4 Scarlet x36Strass da incollare PureCrystal mm. 4 Scarlet x36
Cabochon PureCrystal 4470 mm. 10 Scarlet x1Navetta PureCrystal mm. 15x7 Scarlet x1Cabochon PureCrystal 4120 ovale mm. 18x13 Scarlet x1Cabochon PureCrystal Imperial 4480 10 mm Scarlet x1Cabochon PureCrystal  4470 mm. 12 Scarlet x1
+27
Strass da incollare PureCrystal mm. 4 Peridot Shimmer x36Strass da incollare PureCrystal mm. 4 Peridot Shimmer x36
PureCrystal 5000 Perla rotonda da 8 mm - Peridot Shimmer x1
Strass da incollare PureCrystal mm. 4 Light Siam Shimmer x36Strass da incollare PureCrystal mm. 4 Light Siam Shimmer x36
Strass da incollare PureCrystal mm. 4 Blue Zircon Shimmer x36Strass da incollare PureCrystal mm. 4 Blue Zircon Shimmer x36
Strass da incollare PureCrystal mm. 4 Topaz Shimmer x36Strass da incollare PureCrystal mm. 4 Topaz Shimmer x36
Strass da incollare PureCrystal mm. 4 Tanzanite x36Strass da incollare PureCrystal mm. 4 Tanzanite x36
Abbinamento di strass da incollare PureCrystal Crystal AB x2grAbbinamento di strass da incollare PureCrystal Crystal AB x2gr
Strass adesivi PureCrystal da 3 mm -Crystal Poppy Red Ignite x36Strass adesivi PureCrystal 3 mm - Crystal Dahlia Ignite x36Strass adesivi PureCrystal da 3 mm - Crystal Teal Ignite x36Strass adesivi PureCrystal da 3 mm - Reinvented Light Smoked Topaz x36Strass adesivi PureCrystal 3 mm - Reinvented Smoked Topaz x36
5,80 €
Strass da incollare PureCrystal mm. 4 Crystal Metallic Sunshine x36Strass da incollare PureCrystal mm. 4 Crystal Metallic Sunshine x36
Strass da incollare PureCrystal mm. 4 Crystal Light Chrome x36Strass da incollare PureCrystal mm. 4 Crystal Light Chrome x36
Strass da incollare PureCrystal mm. 4 Fuschia x36
Strass da incollare PureCrystal mm. 5 Fuschia x36Cabochon PureCrystal 1088 mm. 4 Fuchsia x10Cabochon PureCrystal 1088 mm. 3 Fuchsia x20Perle tonde Thin Round  PureCrystal 5034 6 mm - Fuchsia x6Perla tonda Thin Round  PureCrystal 5034 8 mm - Fuchsia x1
+10
Strass da incollare PureCrystal mm. 4 Light Silk x36
Strass da incollare PureCrystal mm. 4 Light Turquoise x36
Strass da incollare PureCrystal mm. 4 Capri Blue x36
Strass da incollare PureCrystal mm. 4 Crystal Silver Night x36
Biconi PureCrystal 5328 mm. 5 Crystal Silver Night x20Biconi PureCrystal 5328 mm. 4 Crystal Silver Night x50Biconi PureCrystal 5328 mm. 3 Crystal Silver Night x50Cuore PureCrystal 6228 mm. 28 Crystal Silver Night x1Cuore PureCrystal 6228 mm. 18x17.5 Crystal Silver Night x1
+35
Strass da incollare PureCrystal mm. 4 Light Topaz x36Strass da incollare PureCrystal mm. 4 Light Topaz x36
Cuori PureCrystal 6202 Light Topaz mm. 10,3x10 x6Perla quadrata 8 mm - Fantasy Square PureCrystal 5035 - Light Topaz x1Perle quadrate 6 mm - Fantasy Square PureCrystal 5035 - Light Topaz x6Perle tonde Thin Round  PureCrystal 5034 6 mm - Light Topaz x6Perla tonda Thin Round  PureCrystal 5034 8 mm - Light Topaz x1
+8
Abbinamento di strass da incollare PureCrystal Crystal x2grAbbinamento di strass da incollare PureCrystal Crystal x2gr
4,83 €
Abbinamento di strass da incollare PureCrystal x10grAbbinamento di strass da incollare PureCrystal x10gr
21,35 €
Strass da incollare PureCrystal mm. 4 Crystal  x36
Strass da incollare PureCrystal mm. 4 Jet  x36
Strass da incollare PureCrystal mm. 4 Light Rose x36
Cabochon PureCrystal 1122 Rivoli mm. 10 Light RoseNavetta PureCrystal 4210 10x5 mm - Rosa chiaro x1Cabochons quadrato PureCrystal 4428 mm.2 Light Rose x10Farfalla PureCrystal 2854 mm. 12 Light Rose x1Cabochon PureCrystal 1122 Rivoli mm. 8 Light Rose
+21
Strass da incollare PureCrystal mm. 4 Rose x36Strass da incollare PureCrystal mm. 4 Rose x36
Cabochon PureCrystal 1122 Rivoli mm. 8 RoseCabochon triangolare PureCrystal 4799 9 mm - Rosa x1Cabochon PureCrystal 4499 6 mm Rosa x1Cabochons barrette PureCrystal 4501 mm.4x2 Rosa x8Cabochon PureCrystal 1088 mm. 4 Rose x10
+24
Strass da incollare PureCrystal mm. 4 Siam  x36Strass da incollare PureCrystal mm. 4 Siam  x36
Navette PureCrystal 4228 mm.6x3 Dark Siam x4Navetta PureCrystal mm. 15x7 SiamNavetta PureCrystal mm. 10x5 SiamPendente PureCrystal 6428 8mm Siam x1Pendente PureCrystal  6428 mm.  6 Siam x1
+19
Strass da incollare PureCrystal mm. 4 Crystal AB x36
Strass da incollare PureCrystal mm. 4 Sapphire x36Strass da incollare PureCrystal mm. 4 Sapphire x36
Strass da incollare PureCrystal mm. 4 Aquamarine  x36
Navetta PureCrystal 4228  mm. 15x7 Aquamarine Ignite x1Navette PureCrystal 4210 10x5 mm - Acquamarina x1Navetta PureCrystal mm. 15x7 AquamarineNavetta PureCrystal mm. 10x5 AquamarinePera PureCrystal 4328 mm. 10x6 Aquamarine
+36
