Filo di ottone Artistic Wire 2,5 mm - grezzo con trattamento anti-ossidazione x 7,6 m
Artistic Wire
Codice : WIR-208
Cono misuratore per  bracciali x1
13,73 €
Cesoie destra di gioielliere 17 cm - per tagliare il metallo x1Cesoie destra di gioielliere 17 cm - per tagliare il metallo x1
8,85 €
Pinza di taglio a molla 13,5 cm con impugnatura ergonomica Perles&co- Blu x1Pinza di taglio a molla 13,5 cm con impugnatura ergonomica Perles&co- Blu x1
Kit di 4 pinze per gioielli per creare gioielli - Di Perles and Co - MentaPinza con naso a molla piegato da 14cm con impugnatura ergonomica Perles&co Blu x1Pinza a becco piegato 14,5 cm by Perles and Co - Satin Touch Coral x1Pinza a becco d'angelo 11,5 cm by Perles and Co - Glitter menta x1Pinza con punta piegata e molla 13 cm by Perles and Co- Menta x1
+25
6,61 €
Pinza a molla piatta con punta in nylon 14cm-manico ergonomico di Perles&co Blu x1
+25
8,94 €
filo braccialetto anello Cuore
Da Francesca (15/07/2026 08:19:27)
Hello, considering that even if there is an anti tarnish treatment this metal tarnishes after longer time, how do you suggest to clean it? Thanks
Il nostro esperto Lucie ti risponde (15/07/2026 10:21:12)
Hello, I would strongly advise you to look after them before the metal ends up rusting or tarnishing. You should avoid showering whilst wearing them. Also remember to take them off before exercising or using household cleaning products. Finally, store them away from moisture and light in a small individual pouch when you’re not wearing them.
Da Francesca (09/07/2026 18:12:16)
Hi, I noticed that after some time this wires tarnishes. How do you suggest to clean it to remove the tarnishment? Will this remove the anti-tarnish treatment? If yes, do you have an anti-tarnish product that can be applied on the wire? Thanks
Il nostro esperto Lucie ti risponde (15/07/2026 10:41:16)
Hello, As this Artistic Wire is coated with a protective varnish, you must avoid using any abrasive or acidic products, as these would damage this thin layer. If it has merely become slightly tarnished, clean it gently with a slightly damp microfibre cloth and mild soap, then dry it immediately. Next, apply a protective varnish specifically designed for jewellery to reseal the surface and permanently stop oxidation.
Il cliente Francesca S. risponde (10/07/2026 11:02:57)
Ok but how do I clean the wire?
Il nostro esperto Lucie ti risponde (10/07/2026 09:27:06)
Hello, you can use anti-tarnish varnish to protect this brass wire. Thank you
