Orecchini a foglia con cerchio aperto 12x8 mm - Dorato satinato con oro fino x2
Codice : EAR-372
Disco in rattan 47 mm Marrone per la creazione di gioielli fai da te x1Disco in rattan 47 mm Marrone per la creazione di gioielli fai da te x1
Paillette ovale 12x10 mm Pietra Gemma - Lapis Lazuli x1
Foglia Charm lavorata 11,5x8 mm - Dorato con oro fino x1Foglia Charm lavorata 11,5x8 mm - Dorato con oro fino x1
Pendente rotondo madreperla 30 mm - Naturale x1Pendente rotondo madreperla 30 mm - Naturale x1
Orecchini a trapezio Star Beads in oro
Orecchini asimmetrici in perle PureCrystal
Da Shira (03/10/2025 03:42:45)
Hello,
I am returning with a problem from my review a year back - The posts of these earrings are scratched from the poussoirs, even before being used. Do you have a recommendation how I can fix it? Scratch it altogether or paint it? - I hesitate because it is the part that will go into a person's lobe....
I will appreciate an advice. Thank you.
Il nostro esperto Manon ti risponde (03/10/2025 13:23:54)
Hello, we are sorry for this inconvenience, please send your complaint with a photo to our customer service at [email protected] so that we can provide you with a suitable solution.
Da Shira (pubblicato su : 06/08/2024 , acquistato su : 08/07/2024)
I really like the look of these earrings and I've bought a few.
All good, but on the minus side:
The post is not always soldered in the middle... but it is ok on the earlobe.
And the posts' matte golden coating gets damaged by the friction of the poussoir. Some items arrived with the signs of that friction and I don't know how to fix it. I intend to use silicone poussoirs to prevent future damage.
Il nostro esperto Laurence R. ti risponde (07/08/2024 08:19:16)
Hello,
We apologize for the inconvenience.
We have contacted the manufacturer to see if they have a solution to this problem.
To make the plating process he has used with the earback joined so maybe this is the reason to this mark. Sometimes he can do it without the earback but he will check it and he get back to us.
Thank you
