Orecchini con base 10 mm per la creazione di bijoux DIY Dorato con oro fino x2
Codice : EAR-153
10 > 99
Cabochon PureCrystal 2035 tondo mm. 10 JetCabochon PureCrystal 2035 tondo mm. 10 Jet
Cabochon PureCrystal 2035 tondo mm. 10 Crystal Antique Pink x1Cabochon PureCrystal 2035 tondo mm. 10 Crystal Antique Pink x1
Cabochon PureCrystal 1088 mm. 8 Crystal Antique PinkCabochon PureCrystal 1088 mm. 3 Crystal Antique Pink x20Cabochon PureCrystal 4320 pera mm. 14x10 Crystal Antique PinkPendente PureCrystal 6428 mm.  8 Crystal Antique Pink x1Biconi PureCrystal 5328 mm. 4 Crystal Antique Pink x50
+2
Cabochon tondo mm. 10 Turchese naturale x1
Cabochon tondo mm. 10 Pietra di luna x1
Cabochon tondo mm. 10 Labradorite x1
Pietra semipreziosa rotonda di 10 mm - Granato x1
Cabochon rotondo da 10 mm - Ametrina x1Cabochon rotondo da 10 mm - Anidrite - Angelite x1Cabochon tondo 10 mm in pietra gemma - Apatite x1Cabochon rotondo 10 mm in pietra gemma - Corniola x1Cabochon rotono da 10 mm - Kyanite x1
+9
Cabochon tondo mm.10 Ametista x1
Cabochon tondo mm. 10 Amazonite x1
Cabochon lente di vetro mm.  10 Crystal x1Cabochon lente di vetro mm.  10 Crystal x1
0,31 €
10 > 49
0,26 €
Cabochon tondo mm. 10 Occhio di TigreCabochon tondo mm. 10 Occhio di Tigre
Biconi PureCrystal 5328 3 mm Rosa Peach Shimmer x50Biconi PureCrystal 5328 3 mm Rosa Peach Shimmer x50
Biconi PureCrystal 5328 mm. 3 Ametista x50Biconi PureCrystal 5328 mm. 3 Amethyst AB x50Biconi PureCrystal 5328 mm. 3 Amethyst Shimmer x50Biconi PureCrystal 5328 mm. 3 Amethyst Shimmer 2X x50Biconi PureCrystal 5328 mm. 3 Aquamarine x50
+104
Orecchini con cabochon di labradorite
Orecchini in tartaruga XXL
Da Sebastian Camilo (29/11/2024 11:11:51)
Hello, I’d like to know which glue would be best for attaching a flat Miyuki piece to this type of earring base. I’ve tried Hasulith, but it didn’t work. Currently, I’m using Strass 244, but I’m still receiving feedback from clients saying the earring base detaches from the woven piece, although the earrings are small or large. Thank you!
Il nostro esperto Tiffanie J. ti risponde (29/11/2024 11:33:38)
Hello, I'm using UHU Bi composant glue or araldite glue to glue the woven piece, then, I use UV Led Resin on the other side. I apply resin on the visible part of the earring at the back and make it flow on the Miyuki piece. Then I use a UV LED Lamp to harden the resin. This way, it's glued on both sides.
Il nostro esperto Manon L. ti risponde (29/11/2024 12:39:28)
The links of the products are in the answer
Il cliente Sebastian Camilo F. risponde (29/11/2024 11:49:41)
Could you please share the links of the products. Thank you!
Da Anonyme (18/11/2020 10:00:51)
Ce clou d''oreille disque était avant à 12 mm dans votre catalogue. Puis là il est passé de 12 mm à 10 mm je l'ai commandé deux fois il correspondait bien au diamètre 12 mm. Changer alors de photo car cette photo ne correspond pas au diamètre de ma dernière commande qui est du 10 mm alors que cette photo corresponds plus à du 12 mm.
Il nostro esperto ti risponde (18/11/2020 10:47:51)
Nous sommes navrés mais nous avons vérifié notre stock et il est correct.
Les clous d'oreilles disques font bien 10mm.
Si vous avez reçu du 12 mm à la place du 10mm commandé, je vous invite à envoyer votre réclamation avec une photo et votre numéro de commande à notre service client : [email protected]
Da Marie-Cecile (pubblicato su : 08/12/2024 , acquistato su : 25/11/2024)
Produit inutilisable car la tige a cassé dans le poussoir dès la première utilisation.
Il nostro esperto Manon L. ti risponde (09/12/2024 09:08:59)
Bonjour, nous sommes navrés pour ce désagrément, merci d'envoyer votre réclamation avec photo à notre service client à l'adresse [email protected] afin qu'on puisse vous apporter une solution adaptée et transmettre l'information à notre fournisseur.
