Pigmenti colorati per hobbistica- Verde tiglio x20 ml
Rayher
Codice : PERS-705
Calcestruzzo creativo x1kgCalcestruzzo creativo x1kg
11,38 €
Calcestruzzo creativo x2.5kgCalcestruzzo creativo x2.5kg
20,95 €
Raysin 200 - Polvere di ceramica bianca per modellaggio x1kgRaysin 200 - Polvere di ceramica bianca per modellaggio x1kg
9,15 €
Raysin 100- Polvere di ceramica bianca per modellaggio Basic x1kgRaysin 100- Polvere di ceramica bianca per modellaggio Basic x1kg
Polvere
Lampada concreto creativo fai da te
Da Yvonne (01/01/2025 14:28:18)
The pigments you use to colour raysin. I know you have some on your site but what kind can you use if I am not buying the ones you sell. Do they need to be certain type? Can I use mica powder? Also when the raysin is curing/ drying in the mould does it heat up or not? Do you need to use something to helo release the raysin if using more closed moulds? Thanks
Il nostro esperto Tiffanie ti risponde (02/01/2025 09:35:31)
Hello, the pigments must be miscible in water. You cannot use alcohol based colorants. Mica Powder won't be very visible inside the Raysin. It doesn't heat up that much. If you use a silicone mold, you won't need anything to release it, but if it's a fragile casting, you may wait one day before releasing it to prevent breaking.
