Plateau 10 compartiments bracelets pour valise de transport bijoux Noir x1
Codice : TOOL-514
Valigia per bijoux completa con cassetti 46x29x40 cm Nero x1Valigia per bijoux completa con cassetti 46x29x40 cm Nero x1
147,41 €
Vassoio a 10 scomparti per custodia per gioielli - Bianco x1
11,19 €
Da Eva (26/04/2025 17:55:22)
Hi, does this fit into TECH-723 case?
If not, is there a single tray that will fit?
Thank you!
Il nostro esperto Manon ti risponde (28/04/2025 17:28:44)
Hello, you can see it is a little difference between TECH-723 and OUT-550. So,the TOOL-514 is not compatible with the trolley TECH-723 only for OUT-550.
