Suggerimento per la tessitura per perle Miyuki e Delica 10 mm - Dorato con oro fino
Codice : ACT-813
+18
> 12
Filo Ko mm. 0.25 White x50 m
Filo Ko mm. 0.25 Light Grey x50 mFilo Ko mm. 0.25 Black x50 mFilo Ko mm. 0.25 Dark Brown x50 mFilo Ko mm. 0.25 Ivory x50 mFilo Ko mm. 0.25 Natural x50 m
+18
5 > 11
Anellini aperti 5x1 mm - Fabbricazione europea - Dorato con oro fino x50
Chiusura a molla 9 mm - Dorato con oro fino x1
Chiusura a molla da 9 mm con anello aperto - Placcato oro 3 micron x1
Chiusura per braccialetto o collana 13 mm - Dorato con oro fino x1Chiusura per braccialetto o collana 13 mm - Dorato con oro fino x1
Tessitura
Tessitura
Le tue domande (3)
Da Emanuela (08/12/2025 09:59:45)
cet embout est-il utilisable avec des rocailles 8,0, pour un tissage RAW?
Il nostro esperto Manon ti risponde (08/12/2025 11:52:53)
Bonjour, non avec des rocailles Miyuki 8/0 cet embout ne conviendra pas car le diamètre des perles est de 3 mm elles sont donc plus grosses que l'ouverture du tube, le tissage ne pourra pas glisser dans l'embout.
Da Romina (03/06/2025 14:30:47)
Hello, The title of this product, ACT-905, ACT-882 and ACT-903 seem almost identical, yet the characteristics list a different origin and plating. In the picture they seem the same kind though. Although the titles say 'gold tone', the list of characteristics alternate between 'gold tone' and 'gold plated', and also origin 'China' vs 'Japan'. Are all of them the same or indeed different despite their similar title? And are they the original Miyuki ones, from the Miyuki brand or a different brand?
Il nostro esperto Lucie ti risponde (04/06/2025 07:47:25)
Hello, there is a difference between these products. When we note gold tone or gold plated it's really different, the plating is not the same, we have a technical data sheet which explains this. The origin is also important, the one from Japan is the original from Miyuki. In the product data we note the brand name, the ACT-813 is the one from Miyuki not the others. Hopefully this is clearer now.
Da Mireille (13/03/2025 11:59:54)
Avez-vous le certificat REACH ?
Il nostro esperto Maeva ti risponde (13/03/2025 13:10:36)
Bonjour, nous venons de mettre le certificat sur la fiche article.
