Miyuki Delica 11/0 DB1537 - Opaque Light Sky Blue Ceylon x8g
Codice : DB-1537
8,54 €
8,14 €
15,86 €
15 > 49
15,25 €
8,14 €
6,71 €
9,05 €
8,33 €
7,93 €
6,41 €
perline marine bracciale
Anello tessuto Miyuki Delicas
Collana fiori in brick stitch
perline tropicale Bracciale
Bracciale Navajo perline
Le tue domande (3)
Da Romina (17/07/2025 10:23:18)
Thank you for your reply. I don't understand how you just state that they're all lead-free and won't add to the listing that they're the -1 numbers. Especially when you for example have TL-2555 still listed, which is a bead with lead enamel. I don't understand how you don't see this is confusing to customers? How will anyone know what they're buying if it doesn't mention the right details?
Il nostro esperto Manon ti risponde (17/07/2025 10:39:18)
TL-2555 It is available while stocks last as indicated in the product sheet :  Discontinued Item.
Da Romina (16/07/2025 16:47:39)
Hi, I'm so confused by your answer. Besides being lead-free, -1 numbers have a different color. For example 1498, 1518 and 1538 are more brownish grays, whereas the -1 versions are more blueish grays. If I order 1498 I'd want a brownish gray and am not expecting to get a blueish gray instead. You're basically selling them under false pretenses. Please consider changing the information so that people know what they're buying, like every other store has done.
Il nostro esperto Manon ti risponde (17/07/2025 10:02:02)
Hello, the color is identical, we update our photos when the new color is slightly different. We have replaced all of Miyuki's leaded references with the new lead-free references, however we have not added "-1".
Da Romina (15/07/2025 15:01:14)
Bonjour:), I was wondering if you have any insight into when the -1 numbers will be available? So in this case DB1537-1, but I'm wondering about all of them in general too, as I haven't seen any of the lead-free -1 numbers on your website so far. It concerns DB106-1, 206-1, 207-1, 209-1, 261-1, 263-1, 264-1, 267-1, 268-1, 354-1, 356-1, 357-1, 384-1, 387-1, 391-1, 675-1, 823-1, 825-1, 827-1, 828-1, 831-1 and 1472-1 through 1538-1.
Il nostro esperto Manon ti risponde (15/07/2025 15:18:00)
Hello, these references are available on our site, there is no "-1" because we could not change the code name of the reference but the beads are lead-free.
