1st step - sewing for beginner the material
Fatto da : Perles & Co
Pubblicato il :18/10/2018
Se siete alle prime armi con il cucito, è meglio acquistare materiali essenziali e di qualità, ma semplici da usare. Forbici per cucire, uno strappacuciture, strumenti per il disegno e gli aghi e il filo giusti sono indispensabili per iniziare bene i vostri primi progetti.
What equipment should you have to start sewing?
First, it is important to know that at the beginning it is better to have little material but good material!
So simple ... stay. but effective!
1er_pas_couture_0
A good pair of scissors: your best ally to start!
They should only be used to cut fabric or they get damaged.
I have a clear preference for 24cm  tailor scissors, for their cutting comfort. The choice will also be based on your budget.
To find your sewing scissors click here: Sewing scissors
1er_pas_couture_d1
The seam ripper
It  undo a seam.
For access to our range is here: Seam Ripper
1er_pas_couture_d2
To mark the fabric before cutting a tracing tool is essential..
Between tailor's chalk, mark pen, chalk pencils, tracer powder, soap ... there also an important choice, there is nothing to lose!
For example, white and blue:  :blue will mark the clear tissue on which the White does not see enough
1er_pas_couture_d3
2 additional marking instruments are: the square and the large ruler  (30cm minimum).
To draw geometric elements on cloth or paper. The square schoolboy is sufficient to start sewing.
1er_pas_couture_d5
Pins to hold two pieces of fabric together.
The basic small  pins with metal heads are fine. But if you are afraid not to see the use color heads!
1er_pas_couture_d4
The essential measuring tape!
1er_pas_couture_d6
Needles.
Take an assortment of different sizes !
The needles it is here: needles
1er_pas_couture_d7
Thread or yarn in every colour.
The number of coils increase as the need arises and sewing projects!
Choose your thread there: sewing thread
1er_pas_couture_d8
Then you need a sewing machine !
1er_pas_couture_d9
Thank you  Bizibul for this notice
Discover her universe here : Bizibul.fr
L'ABC del cucito
Come fare i grembiuli nel cucito?
Come cucire il pregiudizio?
Come seguire un modello di cucito?
Come mettere uno scatto con le pinze?
Come cucire una cerniera perfetta
Mark e tagliare il tessuto
Trova il significato del tessuto
Come cucire le tubature?
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
L'ABC del cucito
Elenco dei prodotti utili
39 bobine di filo da cucire poliestere 146 metri Multicolore
5,09€
Ditale da cucito Prym Ergonomics Taglia M x1
COU-043
5,49€
Nastro da sarta 150 cm - Giallo x1
COU-190
8 in magazzino
3,66€
Scucitore economico piccolo con proteggi-punta 11.3 cm x1
5,49€
Aghi da cucire lunghi n°5-9 cruna argentato x20
1,93€
Aghi per macchina da cucire 130/705 n°70-100 Standard x5
3,15€
12 Pinzette per tessuto 2.6 cm - Prym Love -  Multicolore
6,00€
Mini ferro da stiro a vapore - Formato viaggio x1
32,33€
Regola universale 15x30 cm Omnigrid - Prym - per il cucito e il patchwork x1
23,18€
6 pastelli per cucito - Rosa / Bianco / Blu x1
5,84€
Set di 5 paia di forbici multiuso per ricamo e cucitura
21,86€
14 Pinzette per tessuto 5.5 cm - Prym Love -  Multicolore
10,98€
Perles & Co société Internet & E-Commerce [18/10/2018]
