Résines UV LED
FILTRER43 articolo(i)
Bicchiere in silicone a 2 scomparti per la miscelazione della resina - Trasparente x1
5 et +
Bicchiere graduato in silicone da 100 ml con beccuccio - Trasparente x1
5 et +
Mini lampada UV-LED Cleopatra per resina UV'GLASS - 24W - Nero x1Mini lampada UV-LED Cleopatra per resina UV'GLASS - 24W - Nero x1
24,71 €
Resina UV - Rico Design - Trasparente x10mlResina UV - Rico Design - Trasparente x10ml
Resina colorata UV - Rico Design - Schiuma x10mlResina colorata UV - Rico Design - Schiuma x10ml
Resina colorata UV - Rico Design - Emerald x10mlResina colorata UV - Rico Design - Emerald x10ml
Resina UV colorata - Rico Design - Rosa fluo x10mlResina UV colorata - Rico Design - Rosa fluo x10ml
Resina UV colorata - Rico Design - Magenta x10mlResina UV colorata - Rico Design - Magenta x10ml
Resina colorata UV - Rico Design - Rosso x10mlResina colorata UV - Rico Design - Rosso x10ml
Resina UV colorata - Rico Design - Arancione x10mlResina UV colorata - Rico Design - Arancione x10ml
Resina UV colorata - Rico Design - Quarzo rosa x10mlResina UV colorata - Rico Design - Quarzo rosa x10ml
Resina colorata UV - Rico Design - Rosa x10mlResina colorata UV - Rico Design - Rosa x10ml
Resina colorata UV - Rico Design - Polvere x10mlResina colorata UV - Rico Design - Polvere x10ml
Resina colorata UV - Rico Design - Peach x10mlResina colorata UV - Rico Design - Peach x10ml
Resina UV colorata - Rico Design - Senape x10mlResina UV colorata - Rico Design - Senape x10ml
Resina colorata UV - Rico Design - Limone x10mlResina colorata UV - Rico Design - Limone x10ml
Resina colorata UV - Rico Design - Vaniglia x10mlResina colorata UV - Rico Design - Vaniglia x10ml
Resina UV colorata - Rico Design - Bianco x10mlResina UV colorata - Rico Design - Bianco x10ml
Resina UV colorata - Rico Design - Nero x10mlResina UV colorata - Rico Design - Nero x10ml
Resina colorata UV - Rico Design - Giada x10mlResina colorata UV - Rico Design - Giada x10ml
Resina colorata UV - Rico Design - Denim x10mlResina colorata UV - Rico Design - Denim x10ml
Resina colorata UV - Rico Design - Turchese x10mlResina colorata UV - Rico Design - Turchese x10ml
Resina colorata UV - Rico Design - Aqua x10mlResina colorata UV - Rico Design - Aqua x10ml
Resina colorata UV - Rico Design - Olive x10mlResina colorata UV - Rico Design - Olive x10ml
Resina colorata UV - Rico Design - Petrole x10mlResina colorata UV - Rico Design - Petrole x10ml
Resina colorata UV - Rico Design - Menta x10mlResina colorata UV - Rico Design - Menta x10ml
Resina UV colorata - Rico Design - Viola x10mlResina UV colorata - Rico Design - Viola x10ml
Resina UV colorata - Rico Design - Uva x10mlResina UV colorata - Rico Design - Uva x10ml
Resina colorata UV - Rico Design - Malva x10mlResina colorata UV - Rico Design - Malva x10ml
Resina UV colorata - Rico Design - Lilla x10mlResina UV colorata - Rico Design - Lilla x10ml
Resina colorata UV - Rico Design - Salvia x10mlResina colorata UV - Rico Design - Salvia x10ml
Resina UV colorata - Rico Design - Pistacchio x10mlResina UV colorata - Rico Design - Pistacchio x10ml
Kit di strumenti per la resina - Guanti - Bastoncini - Pipette - Rico Design x1
Resine UV Soft - Trasparente e flessibile x100ml
22,27 €
Cleopatra LED resina UV - Vetro UV x100grCleopatra LED resina UV - Vetro UV x100gr
44,23 €
Resina UV led Cleopatra - UV Glass x25grResina UV led Cleopatra - UV Glass x25gr
12,20 €
150,46 €
Resina Padico UV LED Resin - Moon Drop x200gr
77,26 €
Resina Padico UV LED Resin - Moon Drop x100gr
47,28 €
Resina Padico UV LED Resin - Moon Drop x30grResina Padico UV LED Resin - Moon Drop x30gr
18,30 €
18,30 €
2 spatole Padico ideali per mescolare le resine2 spatole Padico ideali per mescolare le resine
6,00 €
